03 honda rancher 350 problem
Old Aug 19, 2009 | 12:43 PM
hoytultratec's Avatar
Default 03 honda rancher 350 problem
My 03 rancher has 300 miles, I inherited it from my father inlaw who passed last summer,when i got it the machine had 100 miles or so on it, the machine never had any matienence done to it so i changed all the fluids , serviced the air filter the only thing i didnt do was adjust valves.
I have had it up north on the trails 2 times this year and put on a little more then 200 miles and it ran perfect both times, now i havent run it in about a month and went to start it today and i couldnt keep it running without the choke untill it was really warm and it was back firing (more like little pops).
so i know i need to adjust valves, but could this be my problem? i know i have good gas, I guess my other concern is ive been using this filter oil called fab 1 and its some super sticky stuff and works great on stoping stuff,I wonder if im over oiled and its running to rich or something like that.
Im thinking i going to get the valves adjusted first and go from there. any thoughts?
hoyt
Old Aug 19, 2009 | 01:00 PM
1 Bad Honda's Avatar
Try having your carb reuilt and cleaned, mine did the exact same thing you are describing, so i went to a dealer and had the carb cleaned and now it starts right up and runs great! It costed me around $125.00
Old Aug 19, 2009 | 02:19 PM
yep was thinking about pulling the carb and cleaning it, the machine didnt get much use since it was bought and probably did have some bad gas in it the past years.
Old Aug 19, 2009 | 05:53 PM
pulled the carb and cleaned it, it was a little dirty but not bad, still runs like a donkey and backfiring through the carb, if anyone has a rancher look at my other thread the carb one with the pic. so i know if a hose goes on it.
Im thinking valves need to be adjusted.
Old Aug 20, 2009 | 05:25 PM
checked the plug its was pretty fouled and basically finger tight (bad plug could be my prob) gonna pick up a couple of new ones and hope it remedies my problem.
Old Aug 22, 2009 | 02:43 PM
atv bandit's Avatar
I lost the key to my 2003 honda rancher es how can i shift into neutral to move it?
Old Aug 22, 2009 | 08:42 PM
eggenz7's Avatar
should be a tool in the tool kit that allows you to shift the tranny
Old Aug 24, 2009 | 08:06 PM
it was the valves, all fixed.
Sjrpp
May 2, 2023 03:59 PM
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Sjrpp
Jul 5, 2015 09:04 PM
