LT80 case oil
Old Aug 19, 2009 | 07:30 PM
RedDuk's Avatar
Default LT80 case oil
What kind of oil do you guys put in the rear crankcase. I'm rebuilding my sons quad and noticed a bolt on top of the case and said "that looks like oil should go in there". Looked it up on the micro finch and thats what it is. So is it Hypo or regular old 10w-40. Also what is the rear greese zert on the case for. Thanx
Old Aug 19, 2009 | 11:00 PM
onebigzj's Avatar
I used reg 10-30 and the grease zerk if for the rear axle bearings( I think)
Old Aug 20, 2009 | 01:28 PM
rapple's Avatar
I believe that the manual calls for 10w-40 for the case. There's a drain bolt on the bottom, a fill bolt on the top and a level bolt on the side. You fill it until it weeps out the side bolt. If I recall, it's just a little less than 3oz of oil to fill it up. The fill hole is maddeningly tiny, I didn't have a pump type oil can the last time I did mine, so I used a funnel and a tiny plastic tube... it was a 2 beer job just filling it up.
The grease zerk on the rear is for the axle bearings. There are also grease fittings on the front end as well.
Old Aug 20, 2009 | 06:55 PM
RedDuk's Avatar
Thanx for the reply
EIF
Apr 20, 2017 07:15 PM
QuadRiders
Oct 22, 2015 04:13 PM
WilliamBos
Sep 22, 2015 04:07 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
