Wet clutch oil change 199CC
I just purchased a VBike ATA250 Utility with a 199cc engine. I changed the engine oil right away as all has recommended. However, I see a plug on top of the left side (clutch housing) but can not find the drain plug.
Would it be the large chrome plug at the left bottom of the engine, or do I have to remove the front sprocket cover to access the drain?
Side note: So far it runs very good, with a minor carb adjustment, only found one defect. one of the rear luggage rack treaded holes was not tapped correctly. Went over every bolt and nut, found a few loose ones.
Appreciate all who help out here.
Welcome to the forum Texsalmon!
If its like most 200cc engines the clutch oil and the engine oil are the same thing...
After reading your question again im wondering if this is a CVT style of engine...Is this a fully automatic quad?
Njrider1230
Jul 29, 2023 05:16 AM
