trailblazer 250 front wheel bearing replacement
Old Sep 2, 2009 | 06:33 PM
grangecorner's Avatar
Default trailblazer 250 front wheel bearing replacement
Does the front hub just slide off? I need to replace the bearings and I can't get the hub off. It won't even budge. I've taken the brake caliper off and also the castle nut and everything else that needs to come off.
Old Sep 2, 2009 | 07:43 PM
eggenz7's Avatar
should just slide right off. you could try to use a steering wheel puller if its big enough to see if you can pull it off
Old Sep 2, 2009 | 07:49 PM
I tried using a puller already and it still wouldn't budge. It actually started bending the brake rotor
Old Sep 3, 2009 | 05:44 PM
eggenz7's Avatar
might try a little heat around the carrier part of the hub. sounds like you have a seized bearing race thats stickin to the spindle.
Old Oct 8, 2009 | 10:41 AM
Proflow's Avatar
Heat is your best bet only after trying a good penetrating oil. I found that PB Blaster works better than good ol' WD-40 when it comes to stuck parts. Good luck---Proflow
Rooky
10
Jun 23, 2015 09:35 PM
jgreerberube
Jun 21, 2015 02:27 PM
UPLou
Jun 7, 2015 09:42 AM
volsgo30
Jun 4, 2015 06:07 PM
Faraday
Feb 11, 2001 09:28 PM
