1989 Honda TRX350D
Old Sep 7, 2009 | 04:30 PM
Auroranorth's Avatar
Default 1989 Honda TRX350D
I own a 1989 Honda TRX350D that I just replaced the cam chain and upper sproket and the piston rings on. The timing has been set by the factory service manual instructions. The motor runs but sprays gasoline out of the carb intake (the more it revs up, the more spray). I have completely cleaned and adjusted the carb according to the manual, as well. Anyone have any ideas?
Old Sep 7, 2009 | 06:46 PM
Doctorturbo's Avatar
GOT BOOST!
My WAG; your cam timing is off.
To cause a reversion like your describing the intake valve has to be open when the piston is coming up. For that to happen your cam timing has to be off.
Without being there, that's my best guess.
One thing you might do is a compression test. Compression will be down a tad if the cam timing is off.
Old Sep 7, 2009 | 08:04 PM
I have set the timing with the piston at TDC and the cam sproket marks in line with the cylinder head as per the service manual........Which way would I move the cam to correct the problem?
Old Sep 7, 2009 | 08:54 PM
GOT BOOST!
First thing you need to do is double check the timing marks.
They should come out correctly / the book.
You cam is late in relationship to the piston. In other words when the piston is going down in the bore for the intake stroke, when it gets to BDC the intake valve is still open and the piston is going up for the compression stroke and it is blowing out the intake valve.
So as you can see, you need to advance the cam to get it to close the intake valve earlier.
Old Sep 10, 2009 | 07:23 PM
k_902's Avatar
I'm looking at picking up a '89 350, it smokes a bit, but seems to work well... was it hard to place the rings on this bike?
Thanks
wendal
May 9, 2024 09:29 PM
NewGuy2481
Oct 6, 2015 05:54 AM
rgjackson
Sep 17, 2015 11:21 AM
stcspiderman
Sep 13, 2015 05:15 PM
Jason Campbell
Sep 7, 2015 02:25 PM
