Electric start problem
Old Sep 7, 2009 | 05:23 PM
pinetag's Avatar
Default Electric start problem
The electric start doesn't seem to be working on my recon. It was running after changing the oil today and then it just cut off. Now when I push the button it just clicks. The battery is fairly new and I hooked it up to the charger and it is showing full charge. I made sure the terminal bolts were tight also. So I used the pull start and it started up and ran fine, rode it around for a few minutes. Could it be the selenoid or something else? Another thing, the lights come on and the winch works when the machine is off and I just turn the key on so the battery has juice. Bad connectioin somewher maybe?
Old Sep 8, 2009 | 09:09 AM
ddrumman2004's Avatar
Did you check the connections on the solenoid too?
Even though you state that the battery shows full charge on the charger, it won't give an indication of voltage when the starter button is pressed.
It could show above 12 volts with no load across the battery terminals but drop to 9 or below if there is a bad cell(s) in the battery.
How old is the battery and what type is it? Is it a sealed battery or one you buy and have to add the acid and then charge?
Old Sep 8, 2009 | 12:03 PM
pinetag's Avatar
I just bought the batery last Aug so it is right at a year old. It is a Wal Mart atv battery, the kind you have to add acid to and then charge.
The cutting off part has kind of lead me to believe that it is some sort of connection issue. Bad ground maybe? Short? Fuse?
Old Sep 9, 2009 | 08:58 AM
Okay...rereading your post I see where it just cut off..
Start from the battery connections and go from there....checking each connection in the starting circuit from the battery, to the solenoid, to the starter motor itself.
Have you tried jumper cables? Connect to a good vehicle battery but make sure the engine is not running in that vehicle. This will eliminate the battery from being the culprit.
Old Sep 9, 2009 | 09:02 AM
action450s's Avatar
Could be bad brushes in the starting motor. My buddies bike will start with the electric start fine sometimes, then may have to use the kick starter (TRX 300 4x4) other times as it just clicks. All connections are clean and tight.
4xrider
Apr 10, 2017 01:36 PM
rmx251
Sep 10, 2000 11:40 PM
mrdci
Feb 7, 2000 07:16 PM
mrdci
Dec 4, 1999 11:03 PM
hot_shoe_cv
Oct 13, 1999 02:16 PM
