Polaris Clutch Removal Question
Old Sep 8, 2009 | 12:36 PM
Marksvilleman10's Avatar
Question Polaris Clutch Removal Question
Hey guys and gals,
I have a 1993 Polaris 250. I am trying to replace the starter motor but it looks as if I cant get at the bolts without removing the primary clutch. I know that I need to purchase a clutch pulling tool and did find one online for about $25. I am hoping that I do not have to pull off the secondary clutch??? Once I have the new starter installed. Do I need a separate tool to put the clutch back on? Or does it just spin on? Also, does anyone know how many torque pounds I need on the bolt that holds the clutch in? Any help would be greatly appreciated. Thanks in advance.
Tony
Old Sep 8, 2009 | 05:29 PM
eggenz7's Avatar
you CAN take those out it just takes patience and time. remove the air box and carb. you can get at them from the top. i have removed them on all of my 250/400 motors and they *never* get put back
Old Sep 8, 2009 | 06:32 PM
gumbyman's Avatar
no there is no tool to put back on it is a tappered fit... about 90ftp
Old Sep 8, 2009 | 08:46 PM
thanks. I was able to get both primary and secondary clutch off, but am not able to find both the bolts to remove the starter. I found the one on the bottum, but cannot find the other bolt. I have looked everywhere. Do I need to pull of the recoil cover to get at it. I cant believe how difficult this has been to get at this starter. Thanks for any replies.
Tony
Old Sep 8, 2009 | 09:19 PM
ftwflh's Avatar
take the recoil cover off
Old Sep 10, 2009 | 12:27 PM
Thanks for your help. I was able to get it off. Just had to ream on it a bit. It was really stuck.
Rocketx
Nov 16, 2020 07:25 PM
green giant
Jul 13, 2017 12:07 PM
VRRRRT
Jun 27, 2015 09:38 AM
FourWheelOverTwo
May 31, 2015 07:26 PM
Jiggypete
May 30, 2015 07:55 AM
