500 ho polaris clutch grooved ???
Old Sep 9, 2009 | 12:23 PM
KINGSCLEAR's Avatar
Default 500 ho polaris clutch grooved ???
Hi I'm trying to help a buddy ,he has a 2007 500 HO polaris..400 miles. the clutch is engaging harshly @ a high RPM I think he said 6000rpms. He took the cover off and found the clutch has a groove wore in the outer plate where the belt rides. He also says you can see the clutch moving up and down on the shaft? Does any of this make sense or sound familiar to anyone else?
Old Sep 9, 2009 | 02:22 PM
mrtwostroke's Avatar
well the groove is very common, but doesn't seem to cause problems. In my experience.
the high engagement is most likely being caused by something else
Old Sep 9, 2009 | 04:05 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
he has grooves like in the clutch w/ only that many miles he either really burned a belt and or idled for an extremly long times. check to make sure the weights arent worn out as well and the spring isnt broke. i would take the belt off and them remove the cover(center bolt and the 6 bolts) and see if the spring is good then check the weights for grooves out of them and make sure they move freely.
Old Sep 9, 2009 | 04:23 PM
UTU's Avatar
UTU
/\ I agree! /\
Old Sep 10, 2009 | 12:31 PM
rkuhnjr's Avatar
Should put it in neutral when idling that way the belt spins with the clutch and you are less likley to wear a groove in there.
However, how do you fix a groove? can those be lathed? Or are you better off just replacing it? And do you really need to?
Old Sep 10, 2009 | 06:16 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
just replace it. not really anything to fix and it would be very expensive vs buying a new sheeve.
Gtsordo
Jul 13, 2015 10:38 PM
clsharky
Jul 13, 2015 02:07 PM
Shifts
14
Jul 13, 2015 08:41 AM
200es
Jul 10, 2015 09:09 AM
Wnthunting
Jul 9, 2015 03:02 PM
