300ex: new model plastics on older model?
Old Sep 10, 2009 | 10:42 PM
cherokee99's Avatar
Default 300ex: new model plastics on older model?
i have an 02 model 300ex and i want to put newer plastics on it, i think 05+ with the integrated front light. would this work? or did they change the frame mounts?
follow up ?, would it be possible to put 400ex dual center lights on my 300? so i can eliminate the square headlight.
thanks 4 any suggestions!
Old Sep 11, 2009 | 08:23 AM
95wolv's Avatar
I have seen a few pictures of 300exs with 400ex plastic,you have to mod or buy some mounting brackets, so putting newer 300ex plastic on should be totally doable, the frame is identical, you could just get a dealer to show you a blow up picture on the microfiche on what fender mounting brackets have changed, then buy them or make your own.
cornermike
Sep 10, 2015 08:30 AM
chewy78
Sep 8, 2015 10:37 AM
Kenidah
Sep 7, 2015 07:50 PM
Slagpolaris
Sep 5, 2015 09:41 PM
antiguogrumete
Sep 5, 2015 03:41 AM
