300ex: new model plastics on older model?
i have an 02 model 300ex and i want to put newer plastics on it, i think 05+ with the integrated front light. would this work? or did they change the frame mounts?
follow up ?, would it be possible to put 400ex dual center lights on my 300? so i can eliminate the square headlight.
thanks 4 any suggestions!
I have seen a few pictures of 300exs with 400ex plastic,you have to mod or buy some mounting brackets, so putting newer 300ex plastic on should be totally doable, the frame is identical, you could just get a dealer to show you a blow up picture on the microfiche on what fender mounting brackets have changed, then buy them or make your own.
