Polaris XP 850 Belt failure
Old Sep 13, 2009 | 07:18 AM
peebee's Avatar
Default Polaris XP 850 Belt failure
I have a new XP 850 which has broken the belt after 150 kms
110kms easy work on the beach
10kms hard ground then up the beach again one small dune and a little fast stuff.
more than disapointed
HAS POLARIS GOT A PROBLEM, DID I MAKE THE WRONG CHOICE.
Old Sep 13, 2009 | 07:23 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
wondering if its just a bad belt(it does happen). did they replace it or you stuck buying another one? if thier was something out of alignment or something wrong w/ the clutches could be an issue. did the belt shred or break in half? did the belt get burned/overheated? i'm guessing it's not a bad choice as thiers tons on them out there w/ out too many issues. imo
Old Sep 13, 2009 | 07:44 AM
peebee's Avatar
only broke about 2 hour ago, had to be towed back by my trusty 500 efi
a little embrassing seen i was riding with a canam dealer
cruising on 60kms/h (KM not MILES) on a firm beach and bang the belt the shreded, bits came out the breather
i luved my polaris
Old Sep 13, 2009 | 09:00 AM
UTU's Avatar
UTU
First belt problem I've heard of. Unless water got to the belt,mis-alignment of pulleys,bad belt,using low below 10mph,etc?? Let us know what you find out! Perry
Old Sep 13, 2009 | 09:07 AM
TLC's Avatar
TLC
Polaris makes there belt as strong as the ones used in there much highter powered sleds you would think a lower powered ATV would not work up a sweet for there belt system.
Here is another guy with a XP belt failer post. http://forums.atvconnection.com/pola...-my-850-a.html
and this also http://forums.atvconnection.com/pola...h-problem.html
Old Sep 13, 2009 | 09:54 AM
UTU's Avatar
UTU
Arrow 90% & 10%
90% of the time it is operator error operating in high when should be in LOW,water on belt w/o drying belt & clutches,etc,etc. The other 10% will be clutch mis-alignment,clutch break down,bad belt,etc. I have & do work on ALOT of Polaris,Kawasakis and CanAms. Replaced alot of belts on ALOT of them and the MAJORITY of the time its OPERATOR ERROR period...
Old Sep 13, 2009 | 10:00 AM
TLC's Avatar
TLC
The only thing I could say about that Is I have seen belts last along time on Yamaha 350 Bruins,Scramblers, Haweyes, and sleds and they have no low range to speak of.
Old Sep 13, 2009 | 10:14 AM
dirtjunkie's Avatar
They should not be breaking on a new machine like that though.
Polaris has said this is a brand new machine from the ground up, the first year will have some boogers they will need get worked out. Happens to most manufactures the first year of producing a brand new machine
Old Sep 13, 2009 | 10:19 AM
JCDEYO25's Avatar
I haven't seen him here in a while but do you guys remember Sombitch???Didn't he have a belt failure on his XP?
John
Old Sep 13, 2009 | 05:17 PM
The XP can be run up to 39mph in low. The thing that destroys most belts is going slow in high gear. In high gear you want to keep it up at a good speed and stay mostly at a good speed. With the low gear and 39mph ability in low there shouldn't be as much need to use high. See what the manual says about what is the lowest speed you should maintain in high. I'd be interested to know also.
