2000 Sportsmans part identification
Old Sep 13, 2009 | 07:08 PM
chikester's Avatar
Default 2000 Sportsmans part identification
Does anyone know what the part is that is left of the starter solenoid and battery on a Sportsman 500? I thought it may be the voltage regulator but a wiring diagram says it is up towards the front. It makes a clicking noise when you turn the power on.
Old Sep 13, 2009 | 08:30 PM
If you are talking about the plastic pouch,its the thermal fuse (circuit breaker by another name) inside that sends power to the front of the machine. It resets itself if a short happens,plus they are known to go out because of corrosion and heat. Shouldn't make a loud noise,but if working ok,wouldn't worry about it. IF you are worried you can slit the pouch and see if fuse is showing corrosion and could be time to replace before it goes out. I've replaced a few over the years, plus under the front panel depending on model is a couple more.
hugemoth
Jul 20, 2020 03:28 AM
coldnorthpol
Jul 14, 2015 11:22 PM
Shifts
Jul 3, 2015 07:59 AM
Fullblast
May 26, 2015 12:38 AM
sportsman500nc
May 7, 2001 05:22 PM
