new from wiesco
Old Sep 17, 2009 | 09:32 PM
gumbyman's Avatar
Thumbs up new from wiesco
they jumped into the fuel management program...
c/p
Fuel Management Controllers
To get the most out of upgrades like high compression pistons, performance camshafts, exhausts or another power adding components, adjusting the amount of fuel being delivered is a logical next step. Much like re-jetting or adjusting the pilot, needle, and main jet circuit in a carburetor, Wiseco's 3.5 Fuel Management Controllers can really enhance the performance of aftermarket parts.
Wiseco’s new Generation 3.5 Fuel Management Controllers for EFI tuning are extremely simple and easy to use and better yet they require no dyno, complex hookups, power supplies, or extra wiring harnesses! With the push of a button, you can easily adjust fuel delivery by adding/subtracting fuel from each zone to work in conjunction with your latest modifications. The display lights on the controller will display the injector pulse duration, which provides instant feedback for where to make the tuning adjustments. Simply plug the included connector into the existing factory wiring harnesses, mount the controller for easy access, and make the adjustments without ever leaving the seat of your bike/ATV. It doesn’t get any easier than this to dial in your new EFI engine.
This cost effective EFI controller also has data logging capabilities for easy analysis of actual track data. With the addition of an oxygen sensor, it even has the capability to run in full closed-loop mode. This allows users to dial in a specified air-fuel ratio, and the Wiseco controller will hold the air-fuel ratio at a constant set point throughout the entire throttle opening and RPM range. In addition, it has a built-in accelerator pump tuning capability to make up the fuel lost to low vacuum until the revs build.
The Wiseco controller uses the OEM base code, and does not scramble the stock code, which makes going back to the stock setup a snap. This allows the controller to accurately tune the injector pulse duration for consistent, repeatable fuel delivery. These controllers are available for various popular EFI models from Honda, Kawasaki, Suzuki, Yamaha and KTM. Please reference our online search engine to find a controller made specifically for your application.
polarsport500
Apr 29, 2004 07:52 AM
missinglink
Mar 12, 2004 02:16 PM
Rider1169
Oct 3, 2003 06:01 PM
Kickerz
May 30, 2003 11:42 PM
ryenol
Apr 30, 2003 12:53 AM
