2008 Honda Rancer TRX420FE Low Idle
Old Sep 21, 2009 | 11:58 AM
sfdualsport's Avatar
Default 2008 Honda Rancer TRX420FE Low Idle
Does anyone know how to increase the idle on the FI 420?
Old Sep 21, 2009 | 01:26 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
My idle has always been fine, so this has never come up for me. Thought maybe the owner's manual would say something, but a quick look at it and I didn't find anything. A service manual will tell you for sure, or just pop in and ask the mechanics at your dealership.
Old Sep 21, 2009 | 02:48 PM
tramp's Avatar
The EFI system on the 420 does not require or allow for idle adjustment. However the 4 items suggested in the manual that would effect idle are:
throttle operation and or throttle lever freeplay
intake air leak
engine top-end problem
IACV operation
I think it was HondaMechanic that had a piece on here about how to clean the IACV.
You might search on here for IACV.
Old Sep 21, 2009 | 03:19 PM
HondaMechanic's Avatar
If the MIL light isn't flashing then I would check the IACV to see if it was stuck open ..
Old Sep 25, 2009 | 11:12 AM
JeffinTD's Avatar
On EFI Rincons the IAC has been known to get sticky, usually happening in cold weather, and resulting in too slow to keep running, or more often very fast idle once warmed up.
The solution is to take the IAC valve off and spray it clean.
Old Oct 15, 2009 | 07:21 AM
This a brand new machine, I just thought it may help with the backfire that these quads are known for. When going up steep hills and then going down right after the backfire will occur unless I give it a tinny bit of gas as to increase the idle. The quad has 100 miles and 15 hours on it.
Old Oct 15, 2009 | 08:13 AM
Red Rider
The backfire will go away, when the exhaust gets sooted up a little.....
hugemoth
Jul 20, 2020 03:28 AM
hondarider1234
Jul 21, 2015 11:53 PM
CRamshaw777
Jul 18, 2015 05:46 PM
ranvette
Jul 12, 2015 06:34 AM
MNatv89
Jul 7, 2015 11:36 AM
