850 xp winch mount
Old Sep 22, 2009 | 06:03 AM
snowpacker's Avatar
Default 850 xp winch mount
I have a 2009 850 xp and I'm having a hard time finding a mount bracket for a warn winch. any help would be grateful thanks
Old Sep 22, 2009 | 08:03 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Have you contacted Warn? I have seen XP model specific warn winches that come with a mounting plate. Not sure if there are other brand plates to fit the xp as of yet????
Old Sep 22, 2009 | 09:34 AM
bigt2317's Avatar
KFI makes a good one. To get a warn mounting plate you need to buy the winch and mount as a combo. Warn doesn't sell the mount without the winch. If you already have a winch then get the KFI.
Old Sep 22, 2009 | 11:13 AM
snowpacker's Avatar
kfi?????????? what is that web site? phone #
Old Sep 22, 2009 | 12:49 PM
terb's Avatar
Polaris Sportsman XP 550/850 Winch Mount
Location: /Winch Mounts/POLARIS/SPORTSMAN/Sportsman 550 / 850 XP/Polaris Sportsman XP 550/850 Winch Mount
Product Information
Brand new "KFI" Winch Mount for the following Polaris ATV's:
  • 2009-2010 Polaris Sportsman XP 550/850
  • 2010 Polaris Sportsman Touring 550/850
  • 2010 Polaris Sportsman 550 X2
Designed to work with the following winches:
    • KFI: S2000 / A2500 / A3000
    • WARN : U2500 / A2000 / A2500 / 1.5ci / 2.5ci / 2.5ce / 2.5s / 3.0ci / 3.0ce / 3.0s
    • WARN : RT15 / RT25 / RT30 / XT15 / XT25 / XT30
    • RAMSEY : ATV2500 / ATV3000
    • SUPERWINCH : All ATV Winches
    • MILE MARKER: All ATV Winches
    • VENOM : All ATV Winches
    • CHAMPION : C10013 / C10014 / C10018
    • CHAMPION : C20049 / C20049-2 / C20051 / C20249 / C30045 / C30145
      NOTErequires a Roller Fairlead with a 4.875" Bolt Pattern)
    • MANY OTHERS SIMILAR TO THE ABOVE (call for details)
      - Standard ATV Winch 4-hole bolt pattern of 3.00" X 4.875"
      - Standard ATV Winch 2-hole bolt pattern of 3.100"
      - Standard ATV Fairlead bolt pattern of 4.875" Specifications:
  • 100% MADE IN USA
  • Constructed of 10 GA GR50 steel
  • Designed to fit between in the OEM location below the radiator
  • Unlike all other mount competitors our mounts are metal bead blasted before they are powder coated for the best possible finish prep.
  • Powder coated black for supreme durability
  • Mounts the same as OEM intended
  • Works with all Polaris OEM Brush Guards and Double Tube Bumpers
  • Very easy to install
  • Complete installation instructions included
  • All mounting hardware included
  • Will NOT work with Polaris Glacier Plow
  • Satisfaction guaranteed
  • Roller fairlead and winch not included
Why buy the OEM Kit when you can SAVE $100-$150 by getting your Winch separate and buying our High Quality 100% American made winch mount. Your Sportsman is pre-wired with the battery wires pre-ran from your battery to the contactor mount located under your front RH wheel well. We have everything you need in our kit to mount your winch and fairlead.
Price: $38.00
Old Sep 22, 2009 | 07:55 PM
Mongrol's Avatar
"Official Site Skeptic"
WARNING! lol With KFI, the winch mounts upside down & end for end. Also have to move the blue & yellow wire to the other side. Not a big deal & the KFI is a nice product.
Old May 5, 2010 | 04:55 PM
cboelman's Avatar
KFI mount plate is not upside down. There are two plates for the XP. One is the 100740 Standard and the other is a 100740G.
The standard 100740 mounts the winch so that the bottom of the winch is facing the rider (rotated 90 degrees from the ground). With some winches you may also have to rotate the winch from left to right 180 degrees putting the motor on the drivers side instead of the passengers side. This is because of Polaris's design of having the radiator hose where the leads would end up. Some winches can also have the motor leads rotated witch would eliminate the need to flip the winch to the motor being on the drivers side. You can always rotate the motor cover with the sticker on it if you are worried about the sticker.
The Glacier Plow version 100740G will mount the same as the above listed 100740 and also allow the winch to be mounted with the bottom up. Once again With some winches you may also have to rotate the winch from left to right 180 degrees putting the motor on the drivers side instead of the passengers side. This is because of Polaris's design of having the radiator hose where the leads would end up. Some winches can also have the motor leads rotated witch would eliminate the need to flip the winch to the motor being on the drivers side. You can always rotate the motor cover with the sticker on it if you are worried about the sticker.
If you where to buy the Polaris Winch kit, you will get there Polaris branded winch that is mounted upside-down with the bottom facing up. The sticker is orientated in the correct direction because they build these winch kits in China for that specific application.
The KFI mount is designed to work with many different winches and allot of winches have different options for orientations and locations of the motor leads. This was all accounted for in the design of the mount.
They came out with the 100740G model because Polaris decided to make the mounting of the glacier plow system mount to the winch mount. This required them to add additional attachment points, make it a one piece design and make the entire mount out of 3/16 material.
Any questions let me know
Old May 5, 2010 | 05:40 PM
Mongrol's Avatar
I have the Warn RT30 - not Polaris branded, and it mounts reversed as you AND THE KFI INSTALLATION SHEET tells you to do. How ever, it is a good qualitty product.
Old May 6, 2010 | 09:21 AM
colt2245p's Avatar
i put the polaris winch on mine....it was very simple....everything was in the kit and it all bolted up as it was sopposed to ..... took me all of about 40 minutes to install and the bolt holes are in the bottom of the plate for the glacier II snow plow mount
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
EIF
Apr 20, 2017 07:15 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
