04 foreman ES, 4x4 indicator blinks 4 times
Old Oct 5, 2009 | 02:21 PM
PainGiver's Avatar
Default 04 foreman ES, 4x4 indicator blinks 4 times
I saw some similar posts, but nothing too specific.
I just bought a 2004 foreman, and when shifting from 2 to 4 wheel drive while moving, the indicator will sometimes blink 4 times, pause, and repeat. If I shut the machine off and restart, it works fine. If I shift it while it's not moving, it works fine.
I have seen that it may indicate a voltage problem? Is that correct? The bike has a brand new battery and it seems to charge fine and everything works fine. I asked the previous owner and he said it's done it to him and has been that way for over a year, so that would suggest that it's not directly related to changing the battery, though I will recheck the connections.
I'll check the fuses [not at home currently] but what else can I look at?
Old Oct 5, 2009 | 03:14 PM
HondaMechanic's Avatar
Code #4 is "gear position switch system" ... Here are the tests ..
Old Oct 5, 2009 | 03:59 PM
PainGiver's Avatar
Thanks very much. I need to get a service manual so I can find all the parts, but I appreciate your quick reply.
But, I am a bit confused, and that will likely be clarified when I get a manual, but, how does one check for continuity on the various wires to ground if the ignition is switched off and it's an electric shift?
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
honda71
Jul 8, 2015 02:13 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
