ds650 charging system, grounds are good!!!
Old Oct 6, 2009 | 01:41 PM
78 ta's Avatar
Default ds650 charging system, grounds are good!!!
i'm working on a ds650 for a friend, it kills batteries. Got a fresh, fully charged battery, cleaned grounds and subframe connection, and installed a extra ground cable from the frame to the engine....no dice
Still not charging, all I get is bat voltage @12.8v, drops to 11v with lights on and reved up a bit.
I checked red wire at reg/rec and get 12v switch off, black wire from reg/rec to neg bat post checks good.
anybody have procedure to check the charging system and reg/rec? I don't want to buy a manual because it isn't my bike!
are these things known to eat reg/rec or stators?
Thanks
Old Oct 6, 2009 | 02:44 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
You didn't mention the year but the reg/rec does go out from time to time. You should have 12v +/- a few tenths sitting. When starting you should drop no lower than 9v, after running you should be reading 14.25v. If not the Rectifier needs replaced. They are very affordable on ebay.
I'm running one right now that I picked up on ebay about four years ago for $15 including S&H. I put lots of hours and hard miles on my bikes and the auction Regulator has held up well.
Keep us posted.
Old Oct 6, 2009 | 05:44 PM
justme23005's Avatar
I agree, It is probably the regulator/rectifier assembly. I bought a new one for around $50, shipped..
Old Oct 6, 2009 | 09:44 PM
vintageds's Avatar
just went through the same thing,replaced the rectifier,and toasted that,it was the stator,replaced it and now it charges.
Old Oct 6, 2009 | 11:50 PM
78 ta's Avatar
thanks for the replies, does anyone have the procedure and specs to test the reg/rec and or stator for the ds650?
Old Oct 7, 2009 | 10:54 AM
78 ta's Avatar
ok, did some more testing,
I get 20-30+ volts a/c at the yellow wires at the plug at the voltage reg/rec when running depending on rpm , and I get bat. voltage at the red wire, and black wire has cont. to the ground wire at bat.
so I'm thinking the reg. is bad, anybody got a good cheap one?
SOLOLUCKY
Oct 4, 2024 09:09 PM
tmoose
Jun 30, 2015 08:28 AM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
neilbedwell
May 29, 2015 02:24 PM
