2006 Honda TRX 250 leaking fuel at the switch
Old Oct 14, 2009 | 04:06 PM
b8b's Avatar
b8b
Default 2006 Honda TRX 250 leaking fuel at the switch
Hi All,
I cleaned my jets and it is now idling very well, thanks for the tips.
My new issue is that the fuel is leaking pretty significantly at the fuel switch, seems to leak more at off, but also on RES or ON. Not sure what to do about this. Hopefully I don't have to replace the whole tank as it seems built-in.
Any advise on where to start?
Thanks!
Old Oct 14, 2009 | 07:29 PM
1mojave03's Avatar
Your packings are shot, or the o ring that seals it to the tank is shot. You could try cleaning it and check the o ring.
Old Oct 14, 2009 | 08:03 PM
b8b's Avatar
b8b
Is there a DIY guide somewhere that could show me how to do this?
Old Oct 15, 2009 | 08:21 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Get a service manual!
I would pull that tank off, and that would comfirm if the leak is at the valve or below it (like just a cracked line). I have not had to mess with this model, but usually the valve comes off easily, and you can then see if it is the valve itslef or the seals. Should be able to go to the dealer and replace whatever the problem is without to much expense.
green giant
Jul 13, 2017 12:07 PM
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
ranvette
Jun 21, 2015 02:49 PM
Daryl Devine
Jun 8, 2015 08:59 AM
lovinhonda
Jan 25, 2000 09:17 PM
