Smaller rear tires....LT80
Old Oct 21, 2009 | 02:19 PM
rider326's Avatar
Question Smaller rear tires....LT80
How much do smaller rear tires take away from the top end speed of an LT80? I'm looking into buying a set of 16x6.5-8 or 18x6.5-8. I plan on staying with the stock size up front.
Old Oct 21, 2009 | 03:42 PM
DSengineer's Avatar
Has been here a long time!
Its the same thing as making a gearing change. Your just doing it at the tires instead of the sprocket. No different...
Old Oct 21, 2009 | 05:01 PM
rider326's Avatar
I understand going with a smaller tire will give me more low end. I just want to see how drastic the difference is from the 16" to the 18" tire from someone running these, but thanks for the reply.
Old Oct 21, 2009 | 07:44 PM
dave 570's Avatar
don't know about on the lt80, but on my 250x 2 sizes smaller was quite noticable.
Old Oct 22, 2009 | 08:14 AM
LT80's Avatar
LT80 Expert
There is a big difference IMO.
We ran the 16's for MX. Usually a tooth bigger on the front sprocket for the 16's.
Old Oct 22, 2009 | 08:58 AM
rider326's Avatar
Jack, do you run a 13T or a 14T with the 16's.
Old Oct 22, 2009 | 02:37 PM
LT80's Avatar
LT80 Expert
Yes....LOL
As you stated, the 16's are going to give more grunt and less speed.
Depending on your riding condidtions:: big hills and I'd have the stock 12 tooth (428) front. To bring the speed back, a 13 front. If your a flatlander, a 14 front but your not going to rocket out of the hole. Usually for a stock motor, gearing up is what most do. the 14 or even a 15 isn't out of the realm with some roller weight adjustment.
I run a 13/26 with 16's with my motor but the rpm's are increased thus the smaller sprocket is used.
caveeagle
Sep 19, 2015 01:20 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
toonces
Sep 5, 2015 01:14 PM
