Shifting Problems!!!!
Old Oct 22, 2009 | 06:52 PM
rnelson_1984's Avatar
Default Shifting Problems!!!!
I have a 2005 Rancher 400AT. Well its my girlfriends. I have never worked on this type of machine only sport quads. Here is the problems.... Her Brother changed the oil before going hunting and overfilled it. He started having shifting problems. I have just drained about 3/4 of a quart out of it. The esp code blinks 12 times. I have read that this is a shift position sensor. Am I correct?? How can i test to see which one? Any other possible problems?
Old Oct 23, 2009 | 04:33 AM
HondaMechanic's Avatar
Code #12 is an ECM code .. Oil level would have no effect on it ..
Here are the tests for code #12 .. Myself I would first check the shift control motor ..
Old Oct 25, 2009 | 09:20 PM
Well i haven't been able to work on it yet. Partially cause i cant find my multimeter. So this is the first 4 wheeler i have worked i have only had sport quads. Could you tell me where the controll motor is located. Any chance you might be able to email me the shop manual so i could download it?? Thanks for the help!!! any idea on the cost of the control motor and an ecm??
Old Oct 26, 2009 | 05:02 AM
There is not much in the shop manual that helps with code #12 .. Honda doesn't have shift motor dis-assembly info or supply shift motor parts .. Taking the shift motor apart and cleaning the commutator bars/checking brushes and re-assembly is easier with another set of hands .. If your not comfortable taking the small motor apart yourself I get an auto electric shop to check the shift motor ..
component location
shift control motor .. you don't have to remove the front fenders ..
Old Oct 27, 2009 | 06:03 PM
Tested motor...no continuity. Removed and took it apart found a bad spring so i replaced it and bench tested the motor. works fine. Installed it and still same problem
Old Oct 27, 2009 | 07:11 PM
after 6 hours of testing, removing repairing. I have just about gave up on this. What would be the reason for not being able to intialize it...cause i tried that and it wont let me!!!!!
Old Oct 28, 2009 | 04:29 AM
Where did you get the spring for the shift motor ..
Old Oct 28, 2009 | 07:19 AM
I found one that had about the same tesion and about the same length. when i bench tested it off the battery it worked great.
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
