1994 400L 4x4 Engine Cranking issues
Old Oct 25, 2009 | 11:14 AM
fastestdriver01's Avatar
Default 1994 400L 4x4 Engine Cranking issues
I was given a 400L 4x4 basket case and am trying to get it going for hunting season. I have never owned a 4 wheeler before, but am good with engines and vehicles. My 1st problem is that the starter won't turn the engine over. So I tore it apart and rebuilt it. Bench tests great. Still won't turn the motor over. New selenoid. Still not. I replaced the broken pull rope and tried to pull start it. No Go. Won't budge. I pulled the head off to see if it was seized. Cylinder looks fantastic. Measured, not out of round or tapered. I pushed on the top of the piston with a hammer handle and got the piston moving down. Now, it pulls about 2 crank rev. and locks up. I smeared engine building lube on the cylinder walls to ensure lubrication while checking everything else out. I have 2 concerns, 1) the magneto is locking up, and the most obvious 2) bearings are shot, particularly the rod bearing. Is there a common problem with these in the bearing areas? How difficult is it to tear these engines apart?
Thanks in advance!!!!
Old Oct 25, 2009 | 03:57 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
have to wonder if it was run w/ no oil(injection stopped working or didn't use premix) to the bearings and froze up? bearings would be my first guess.
Old Oct 26, 2009 | 06:43 AM
drlang's Avatar
If the skirts have broken on the piston, which is very common. don't turn this thing over, what happens is a piece of the skirt gets lodged between the crank and the cases. Then the crank pushes the piece thru the case. Diasassemble the engine and inspect all. Spend 50.00 on a gasket kit to save a whole lot. Doc
2x_lung
1) Engine problems..
48
May 24, 2023 05:22 AM
Hankey Pankey
26
Oct 18, 2020 03:50 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
scaldwellk
Jun 19, 2015 05:08 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
