LT/KFX80 - lots of smoke when cold
Old Oct 26, 2009 | 11:24 AM
DSengineer's Avatar
Has been here a long time!
Default LT/KFX80 - lots of smoke when cold
Is it normal for these things to put out a lot of smoke when cold and still using the stock oil injector? The smoke lessens as it warms up. Would blocking off the injector and going 40:1 pre-mix help with the smoke? The bike runs great but the smoke is a bit of an annoyance especially if I need to start it up in the garage.
Old Oct 26, 2009 | 03:19 PM
DSengineer's Avatar
For what its worth it is currently running Redline oil in the oil tank.
Old Oct 26, 2009 | 10:40 PM
aaronrkelly's Avatar
Normal.....and I like to see that smoke, means my boys 4 wheeler is getting proper lubrication. Like you said, it lessons once its warm and definitely at speed. Push it outside before you start it, problem solved.
I dont have your answer on the pre-mix....Im a big fan of the oil injectors. Even if they dont work when I get a quad or bike I always make them work.
Old Oct 27, 2009 | 08:31 AM
LT80's Avatar
LT80 Expert
Redline is supposed to be a very good oil. I'm wondering if it's meant to be used in a injection system. Some oils are not made to be injected.
I'm not a fan of the injectors. They work good till they don't then it's piston/bore time.
I'd run 32:1 if you remove the injection.
dirt ryder
Sep 27, 2015 09:22 PM
KSJOHN
Aug 30, 2015 08:15 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
Dirtbikemike1
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
