rubicon troubles
Old Oct 27, 2009 | 04:48 PM
riverrat84's Avatar
Default rubicon troubles
I got a 2007 rubicon thats showing a code six. It will take of and run fine for a min than it shifts itself to first gear and stays there. It also sputters in reverse. I just changed the angle sensor but it didnt do any good. any suggestions?
Old Oct 27, 2009 | 06:53 PM
HondaMechanic's Avatar
Did you pre-load the angle sensor when it was installed ..
Old Oct 28, 2009 | 03:52 PM
riverrat84's Avatar
Thumbs up thanks
Thanks man I didnt know to do that went back primed it and know it aint throwin any codes and its runin normal. Lets see if it lasts, Thanks again for the feedback first time on the forum and it paid of.
Old Oct 28, 2009 | 04:34 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
There are always rev limiters, to prevent you from killing yourself in reverse! Guessing that is what the sputter is.
Old Oct 29, 2009 | 02:52 AM
JeffinTD's Avatar
The sputtering in reverse is part of limp mode.
Old Oct 29, 2009 | 11:20 AM
riverrat84's Avatar
Ok I primed the angle sensor and that got rid of the sputter and the code. Unfortunitly the problems not totally fixed its runnin great but it wont down shift until you come to a stop. So it will run through the gears just fine until it gets to high then if u go up a hill it wont down shift. I have to come to a total stop than it will shift to 1rst. If I put it in esp I can manually shift with no problems. Any advice would be appriciated. thanks
Old Oct 30, 2009 | 09:15 AM
faruquehabib's Avatar
a rubicon doesnt have any gears, other than forward and reverse. it is an infinitely variable hydromechanical transmission.
Old Oct 30, 2009 | 10:05 AM
colt2245p's Avatar
i guess you have never been on a rubicon. yes its variable drive but in esp mode it has 5 preset drives/gears. you shift it just like you would any es honda
Old Oct 30, 2009 | 10:55 PM
rubicon 500 itp's Avatar
colt you dont even know your own atv, the rubicon has 5 ratios in the hydro static trans, if you cant fix things yourself bring it to a shop
Old Oct 31, 2009 | 12:27 AM
riverrat84's Avatar
this thread wasnt started by colt it was started by riverrat84 and yes i know its got 5 ratios and if I could afford to take it to a shop it would be there. I know I aint know expert but im prety good with a wrench im just trying to figure out what the the problem could be so i can fix it if you aint here to help there aint no need to reply I dont go around bashin your threads I expect the same courtesy. I fixed the sputter in reverse and got rid of the code but it still aint down shiftin unless you come to total stop or shift it manually in esp. If anyone has some good advice and not highschool bs it would greatly be appriciated!!
