rubicon troubles
Old Oct 31, 2009 | 05:24 AM
HondaMechanic's Avatar
Initialize the ECM and re-test ..
Old Oct 31, 2009 | 07:24 AM
colt2245p's Avatar
Originally Posted by rubicon 500 itp
colt you dont even know your own atv, the rubicon has 5 ratios in the hydro static trans, if you cant fix things yourself bring it to a shop
obviously you dont know much adout a rubi trans.........if you would like to discuss just how it works lets do it somewhere else.....didnt mean to hijack someone elses post whos looking for help
Old Oct 31, 2009 | 08:29 AM
rubicon 500 itp's Avatar
river rat i did not mean anything to you i said it to colt because he was accusing someone that they didnt know rubis , when they were stating correct info. a rubicon does have 5 speeds but they are ratios, that is why the shift seems almost no existent were as a rincon bucks a bit during its shifts and are much more noticeable i am sure you all probually know this already. colt2245p i have a question for you, what is a better quad your sp500 or your rubicon. i was stuck between them when i bought my rubicon
Old Oct 31, 2009 | 10:23 AM
colt2245p's Avatar
for use as a utility bike the honda is the better machine for farm/houshold chores....as far as riding on a 40 or fifty mile ride the popo is much better. it runs better it handles the trails better and doesn get stuck in the mud holes as easy......as far as the rubi trans goes it is a variable speed drive using hyraulics. the engine drives a piston pump which pushes oil agianst another set of pistons which are on a swash plate connected to the output shaft therefore giving infinate drive ratios. in esp mode the swash plate stops at predetermined outputs therfore giving you gears in a sense....
Old Oct 31, 2009 | 10:25 AM
  #15
colt2245p's Avatar
also my comment was not for river rat......
Old Nov 1, 2009 | 05:17 PM
  #16
riverrat84's Avatar
Thanks for the info HondaMechanic Ill give that a try and let ya know if it works.
Old Nov 3, 2009 | 11:24 PM
  #17
riverrat84's Avatar
Just wanted to let yall know initializing the ecm worked. Its been two day with no problems. Its like having a new four wheeler. Thanks to all for there help. I only spent about $90 to fix the problem, it would have been a lot more without yalls help and HMs expertise thanks again.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
