scrambler 400 2x4, cannot change gear.
Hi again everyone,
As they say, when it rain it pours, I got another issue with my scrambler... I can turn it on in gear with no problem, I can change from forward to reverse to neutral, but soon I put it in neutral I cannot change it to forward or reverse, I have to turn it off and change it then turn it back on. When it's in neutral and i try to shift forward or reverse, it grids.
Please help.
Thank you.
Please help.
Thank you.
if you look at your carbrator there should be a big screw(most likely a phillips head) w/ a spring (it should be the biggest screw/spring)on the side of the carb that you can turn counter clockwise(turning out/loosening)slowly about 1/4 turn to slow the idle down. you should be able to listen to the engine when it slows down to know if it's working. do a little and try shifting until it works for you.
mitchxc700
Aug 10, 2015 09:26 PM
