scrambler 400 2x4, cannot change gear.
Old Oct 28, 2009 | 01:57 PM
horzman's Avatar
Default scrambler 400 2x4, cannot change gear.
Hi again everyone,
As they say, when it rain it pours, I got another issue with my scrambler... I can turn it on in gear with no problem, I can change from forward to reverse to neutral, but soon I put it in neutral I cannot change it to forward or reverse, I have to turn it off and change it then turn it back on. When it's in neutral and i try to shift forward or reverse, it grids.
Please help.
Thank you.
Old Oct 28, 2009 | 07:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is your idle set too high causing it to grind, or maybe the shift linkage is not set right?
Old Oct 28, 2009 | 09:47 PM
horzman's Avatar
the idle seems to be too high, but I don't know how to adjust it... does anyone knows how to ?
Thank you.
Old Oct 29, 2009 | 04:22 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you look at your carbrator there should be a big screw(most likely a phillips head) w/ a spring (it should be the biggest screw/spring)on the side of the carb that you can turn counter clockwise(turning out/loosening)slowly about 1/4 turn to slow the idle down. you should be able to listen to the engine when it slows down to know if it's working. do a little and try shifting until it works for you.
Old Oct 29, 2009 | 07:22 PM
horzman's Avatar
Thank you Stendori, that was the problem... it works good now.
Thank you.
Old Oct 30, 2009 | 05:09 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
your welcome.
mitchxc700
Aug 19, 2015 02:41 AM
scram5050
Aug 19, 2015 02:19 AM
mitchxc700
Aug 10, 2015 09:26 PM
1000gade
Aug 9, 2015 03:34 PM
maxjung
Jul 13, 2015 05:11 PM
