Extended cargo rack
Old Oct 29, 2009 | 05:54 PM
gaspumpcity's Avatar
Default Extended cargo rack
Anyone know if I can have both front cargo box plus the rack extender on an XP. I have seen them for the rear just want the option to sometimes remove the lock and ride box.
Old Oct 29, 2009 | 07:24 PM
nc porider's Avatar
Default extended cargo rack
nope if you get the cargo box you can't use the rack extender on the front
Old Oct 31, 2009 | 10:22 PM
I found this looks like I can have the cargo box and run the extender Pure Polaris : Sportsman XP Front Rack Extender).
Old Nov 1, 2009 | 07:29 AM
rancher55's Avatar
If you have the stock front rack, the extender will mount to it for use without the front box in place. I don't know of any way to use the rack extender with the storage box on without some modifications to the way the extender mounts, such as mounting it directly to the storage box's lid. That may work, but I'm not sure.
Old Nov 1, 2009 | 08:50 AM
This is printed at the bottom of the page let the page completely load anyway here is what it says--------This Front Rack Extender adds convenience and cargo carrying versatility to a Sportsman XP. This 4.5”-high Extender is made of injection-molded nylon and is extremely strong and durable. It is engineered to fit specifically on a Sportsman XP front cargo rack and it will work with the XP Cargo Box and Gun Scabbard Mount (each sold separately). It provides a wealth of tie-down points so you can keep cargo securely in place.
Old Nov 1, 2009 | 09:08 PM
deerwagon's Avatar
I believe the quote you posted is only referring to the rear rack extenders. I have the front and rear rack extenders - I bought the metal ones - They have composite ones that I didn't want. Make sure you specify metal (powdercoated) ones if thats what your looking for. FYI - to mount the front rack you remove and replace two of the existing bolts. You then have to drill 2 new holes through the composite rack to mount the front two bolts. I can post pics if your interested...Jeff
Old Nov 2, 2009 | 10:35 AM
rancher55's Avatar
I have an XP like gaspumpcity is referring to in this post and no drilling or bolts are required to mount either the front rack or storage box. They are both Lock and Ride attachments.
Unless you are talking about mounting the extender to the rack.?....
And what about with the box in place?
Pic's are always good!
badgerboy1
Sep 26, 2017 06:11 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Rick Van Matre
Sep 11, 2015 11:52 PM
