250X bogging down at full throttle??? HELP!
Old Feb 23, 2001 | 11:25 AM
DSAPP's Avatar
last night we went riding in the snow...
all night, the snow continued to fall, it was blowing and breezy and I was always behind someone getting roosted...
anyway... anytime I ran wide open for more than a minute or two, it wanted to bog down and stall out when I let off the gas...
I had to constantly downshift to keep the rpms up to keep the motor from stalling...
yet, when I came to a stop, it would idle just fine... but when I tried to give it gas it would bog and stall...
after letting it idle for a minute or two, I could gradually hold on the throttle until it cleared up, and I could ride again...
this happened all night long.
ANYONE have any idea what was happening to my quad?
my theory was that at high speeds, snow was accumulating in my air intake frame tubes, choking the engine... and after letting it set for a few minutes, the engine heat melted the snow and I could continue...
what do you think???
Old Feb 23, 2001 | 01:12 PM
THEXOTIC1's Avatar
when was the last time the clearence of the valves where checked. Also sounds like the main jet may be clogged in the carb
Old Feb 23, 2001 | 02:05 PM
DSAPP's Avatar
I have the valves and clutch checked every 6 months...
I was riding with a mechanic at the time, he said it was acting like there was water in the carb...
possible, since it was snowing and blowing so much... but why didn't it happen to any of the other quads???
Old Feb 23, 2001 | 09:16 PM
bayou220atv's Avatar
What are the symptoms of valves needing adjusting? just wondering because when I give my quad a bump of throttle at idle it will stall, unless the RPM's are up a little bit allready, but on a dead stop and I punch the gas it will stall on me. It's not that it's flooded either because it starts right back up easily.
Old Feb 23, 2001 | 11:55 PM
rustyjones's Avatar
Check the needle jet.I had a clip break once and drop the needle.It ran just like you described.
Old Feb 23, 2001 | 11:57 PM
rustyjones's Avatar
Also was it really cold?Could be your carb was frosting over.And when you let it sit for awhile it would melt do to the heat from the engine.
Old Feb 24, 2001 | 02:07 PM
bermbanger's Avatar
turn the mixture screw clockwise about 2 times to keep it from stalling after you punch the trottle. Sounds like you had a lot of water in the carb and a fouled plug too
Old Feb 24, 2001 | 03:53 PM
ATV_MAN's Avatar
Sorry this isn't about your carb DSAPP...
Bermbanger- Is there a screw to adjust the fuel richness on the 200SX's carb??...I know about the idle screw but I can't see any other screws to adjust...is their??
Old Feb 24, 2001 | 10:50 PM
bermbanger's Avatar
yes there is.look on the other side of the carb.it won't be as big as the idle screw or just look at your manual
Old Feb 25, 2001 | 10:22 AM
love250x's Avatar
My 250X sometimes does this in rain, I would just take the bowl off the carb. and dump the gas and water out, replace and when it gets gas back into the carb., try to see if it runs better, good luck, I know how much fun snow is
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Polarisman1123
Sep 13, 2015 10:06 AM
Sjrpp
Jul 5, 2015 09:04 PM
