Oily Soot in Airbox/Belt??
I have an '06 Sportsman 450. Today while going on a real quick ride I noticed my belt was slipping very badly. It is a new belt and doesn't have more than 500 miles on it. Two days ago when I rode there was no slipping at all. When I took everything off to inspect it I noticed the inside was full of like a oily black soot. Every so often when I clean the air filter it is always full of the same soot. First, what is causing the soot, and second would that be making the belt slip? When I cleaned it all off and put everything back on the belt wasn't slipping. I have never rolled the machine or anything like that either.
Fine black soot is normal after some miles. It is from the belt ware. The cleaner you can keep the clutches the less they will slip and save you a lot in replacement parts also.
Use a air compressor to blow it out good and the wipe down clutches with a contact or brake cleaner that doesn't leave an oily film.
Not sure what would cause that in the air filter.
Steep inclines will get oil in your air box, no proplem Polaris even has a drian plug for that.
Once water gets in you belt housing it causes a dark grey soot mess everywhere but the slipping should goes away once the water evaporates,because the belt friction will clean off the soot from the inside sheaves where it matters.
