Storing a single cylinder motor
Old Nov 6, 2009 | 10:01 AM
budedm's Avatar
Default Storing a single cylinder motor
Wouldn't it be best to get the piston at TDC on the compression stroke for long term storage? That way no moisture or anything could get into the cylinder. Just wondering.
Old Nov 6, 2009 | 10:22 AM
TLC's Avatar
TLC
Fog the motor, and put gas stabilizer in the gas tank.
While the engine is running, and spray fogging oil into the air intake. Give it an extra heavy shot just as the engine starves and dies.
Here a pic of one brand but there all good enough.
Old Nov 6, 2009 | 10:46 AM
budedm's Avatar
"Fog the motor, and put gas stabilizer in the gas tank."
Yes. I do both of these. But, as an extra precaution, wouldn't it be best to get the piston at TDC on the compression stroke? Specifically, I'm talking about my Troy Bilt Chipper & tiller. Both are 8hp Briggs motors.
Old Nov 6, 2009 | 10:52 AM
TLC's Avatar
TLC
The Fog oil film will stick on the cyclinder wall and never run down or off,so it does not matter what the piston position is.
Old Nov 6, 2009 | 12:14 PM
budedm's Avatar
But what about the valves? Wouldn't it help if they were closed?
Old Nov 6, 2009 | 12:23 PM
TLC's Avatar
TLC
Not really that fog oil gets into all over those parts also. Remember your spraying it into a running motor until it stalls so its gets into everything,head,rockers,valves,cams.wrist pins. Even the crank case if it was a 2 stroke.
Old Nov 6, 2009 | 01:17 PM
budedm's Avatar
Ok. I guess I was more concerned with foreign objects getting into the cylinder. I had a motorcycle once where mice got into the muffler and built a nest in the pipe. So I guess I was thinking if mice can do that, it would be possible for bugs or ants or even moisture to get into the cylinder via the valves. Either thru the carb or thru the exhaust.
Old Nov 6, 2009 | 01:35 PM
ddrumman2004's Avatar
I have a tiller from the old Central Hardware stores that was give to me over 11 years ago with an old 5hp Briggs motor.
It sits outside under a galvanized washtub and has sat as long as 3 years at one time with nothing done to it.....and I mean nothing.
But it runs.......and has never...ever...failed to start.
And it uses no oil.
If it failed on me today, tomorrow or whenever, I have no room to complain about it.
Old Nov 6, 2009 | 01:40 PM
PainGiver's Avatar
I do turn my engines over to the compression stroke. I've never used fogging oil, but will probably do that now.
I've always just drained the carbs, put stabilizer in the gas, and turned the engine over to compression stroke.
Not saying it's the best, just what I've done in the past without any issues.
Old Nov 6, 2009 | 02:15 PM
budedm's Avatar
I just got off the phone with Briggs & Stratton. The guy said it doesn't really matter. In fact, his opinion is that you should leave it on the downstroke between exhaust & intake so that both valves are open. This allows air flow through the cylinder so it keeps moisture out. Much like vents in a crawl space of a house. I told him it seemed that if the valves were closed on the compression stroke, moisture wouldn't get in. He said there is some merit to that thinking but moisture gets in anyway, and when it does, there's no way to get it out. But in the end, he said it really didn't matter. He said "It's a 7 hp Briggs, not a nuclear power plant. Don't worry about it. Where ever it stops, store it." lol
