Storing a single cylinder motor
I just got off the phone with Briggs & Stratton. The guy said it doesn't really matter. In fact, his opinion is that you should leave it on the downstroke between exhaust & intake so that both valves are open. This allows air flow through the cylinder so it keeps moisture out. Much like vents in a crawl space of a house. I told him it seemed that if the valves were closed on the compression stroke, moisture wouldn't get in. He said there is some merit to that thinking but moisture gets in anyway, and when it does, there's no way to get it out. But in the end, he said it really didn't matter. He said "It's a 7 hp Briggs, not a nuclear power plant. Don't worry about it. Where ever it stops, store it." lol
Why? Because the valve springs are at rest. The pro's say is does not make much difference if the valve springs are loaded or unloaded. I have to back the rockers off of the race car this month so you can see where I stand on this issue. I like them unloaded.
I have a 50 year old Briggs. Yes, 50 years old. It gets no special treatment and every year it starts and runs perfect. No 15 buck a quart "Recon" super oil. No drained gas. No Stabil. No nothing, and it starts and runs on about the third pull year after year.
It's good to think about these things, but no reason to over think it either.
SixSpeed5
8
Aug 2, 2015 05:38 PM
TLC
Jul 11, 2015 02:28 AM
