Question about Honda CR250 and CR500 2-Stroke engines
Old Nov 8, 2009 | 10:01 PM
HOWITZ3R's Avatar
Default Question about Honda CR250 and CR500 2-Stroke engines
This is probably a stupid question and I think I already know the answer, but i'm going to ask it anyway. Does anyone know if the engine mounting points on the engine are relatively the same between the CR250 and the CR500 engines? I know that on both engines they use three mounting points. All help will be appreciatted.
Old Nov 11, 2009 | 06:22 PM
250arrrr's Avatar
If you are attempting to put the 500 motor in a 250 frame then there will be a little work. The rear mount works out as well as the bottom. The major problem you are going to have is the exhaust flange hitting the Y in the downtube. You will have to modify this for it to work or you can't get the flange on.
Hope this helps.........
Old Nov 14, 2009 | 09:22 AM
HOWITZ3R's Avatar
This does help, but I was thinking about putting a 500 2-stroke into a 400EX frame. Service Honda offers a kit to put a 250 2-stroke into a 400EX frame so i was thinking maybe I could take those engine mounts in that kit, since i don't have any metal working equipment, and mount up a 500 2-stroke to the 400EX frame if the engine will physically fit into the frame. If you have any information on this it will be greatly appreciated.
neilbedwell
Nov 10, 2018 11:02 AM
scaldwellk
Jun 19, 2015 05:08 PM
hugemoth
Jun 4, 2015 02:56 AM
lovinhonda
Jan 25, 2000 09:17 PM
jgardn1
Nov 28, 1999 09:46 PM
