Rear Axel for DS 650 Baja -2002 year
Old Nov 9, 2009 | 05:53 PM
vijay's Avatar
Default Rear Axel for DS 650 Baja -2002 year
Ok, I need a rear axel for my fixer upper DS 650 (2002). Now, are there any aftermarket makers for these? Also, just curious, can I get wider rear axle than OEM? Does it affect steering geometry? I have seen wheel with large off set on these so figured I might as well get a wider axel instead of larger off wheels. Just a thought.
Old Nov 9, 2009 | 10:38 PM
A_GR__N69's Avatar
BOMBARDIER <---check here at the bottom of the page very bottom.
or you might want to check the WHAT'S IN YOUR GARAGE--> here's the link http://forums.atvconnection.com/can-am-brp/86920-whats-your-garage.html.... I just bought my 2002 ds650 axle from Bigdaddy660. There's stuff in there you just got to look.
And while you have your axle out in never hurts to buy this AKA replace the bearings. Way better then the stock carrier. http://cgi.ebay.com/ebaymotors/MAGNU...item2ea84d3a3c
NLWarrior01
Jun 28, 2015 12:54 PM
Jun 15, 2015 11:22 PM
JackTheKing
Jun 14, 2015 03:04 PM
Jun 8, 2015 06:45 PM
Biggieshortie89
May 26, 2015 08:01 AM
