1987 honda 250 fourtrax help
Old Nov 16, 2009 | 07:57 PM
honda nation1's Avatar
Default 1987 honda 250 fourtrax help
hey so winters comin and i was wondrin i got a 2wd bike and i wanna know a good snow/ice or snow/mud tire to buy please help
thanks
Old Nov 18, 2009 | 03:56 PM
honkaw's Avatar
If you scroll down farther on the home page of this forum there is a disscussion board specificly on tires and wheels this might help you. I really like the Bear Claws I put on my Mojave got them from BikeBandit.com if I remember right
Old Nov 19, 2009 | 11:08 AM
PainGiver's Avatar
Yeah, I had bear claws on an 86 I just sold, and I liked them a lot too.
Old Mar 18, 2018 | 10:05 PM
Leslie meadows's Avatar
Default Stumped
1987 Honda 250fourtrax new stator, new cdi box "the big one" new coil new ignition switch, new plug. All switches work. No fire on the coil. No power to the cdi box.
Old Mar 19, 2018 | 04:03 AM
Default Stumped
UOTE=Leslie meadows;3389046]1987 Honda 250fourtrax new stator, new cdi box "the big one" new coil new ignition switch, new plug. All switches work. No fire on the coil. No power to the cdi box. [/QUOTE]
why are there two cdi boxes on this atv? And what do they do?
Old Mar 19, 2018 | 07:38 AM
Default Stumped
why are there two cdi boxes on this atv? And what do they do?[/QUOTE] any ideas?
Old Mar 20, 2018 | 02:56 AM
You would have been a lot better starting a new posting than adding to a 9 year old one about tyres. The 250 has only one CDI, I would guess that you are mistaking the oil alert "black box" or the voltage regulator for a CDI.
The 250 was one of the last Hondas to have the separate exciter coil on the alternator, start by checking that this is producing a healthy AC voltage when the engine is spun on the starter. Then check the trigger coil is producing an AC pulse, usually a lot smaller voltage, may even be less than 1v. Hondas usually have a device that increases spark strength when in neutral, wired between the neutral light and CDI, check this is working. Check the kill wire is working. If you want to check everything properly, buying a workshop manual is a good idea. Never just fit a new CDI, as the old one may have blown because of a fault somewhere else, a good earth to it is vital or the new CDI will blow and, once running, always check the voltage regulator isn't overcharging, or it may blow the new CDI.
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
rgjackson
Sep 17, 2015 11:21 AM
stcspiderman
Sep 13, 2015 05:15 PM
Steeldon
Sep 8, 2015 10:51 AM
Jason Campbell
Sep 7, 2015 02:25 PM
