KLF 185 disconnect shaft drive to remove engine?
Old Nov 20, 2009 | 09:49 PM
artjtrout's Avatar
Default KLF 185 disconnect shaft drive to remove engine?
I picked up 2 klf 185's cheap, one fixed with simple clean of tank fuel pump and carb, runs great. Second is cleaned up but won't start, compression is almost nill so I figure rings or valves. I'm at the point of removing the engine to do a top end re-build, but how do I detach the shaft drive from the engine? If just unbolt he rear axle, can I just slide it back and will it just unslpine from the engine? There is also a small crack at the fuel tank filler, is there a way to glue it?
Thanks in advance for any help!
Old Nov 21, 2009 | 02:39 PM
artjtrout's Avatar
So I undid the axe, slid it back an inch or so, undid the last mounting bolt on the engine and it slid forward and desplined off the shaft and came right out.... Breakdown time, wish me luck that the cylinder is not screwed!
Old Nov 21, 2009 | 07:58 PM
artjtrout's Avatar
And the verdict is....Blown head gasket!
tiresharkdbb
Sep 3, 2017 02:06 AM
txkevin
Sep 21, 2015 02:02 PM
ku4gi
May 4, 2001 11:10 AM
Oldman500
Feb 26, 2001 09:47 PM
exmxer
Dec 7, 2000 01:29 PM
