no spark from a 200cc beast
Old Nov 23, 2009 | 07:43 AM
reganl's Avatar
Default no spark from a 200cc beast
one question i have no spark. ac ignion power is 56> but when i go to ignition trigger pulse it is 0> does this mean I need a new stator/ ignition pulse trigger> or should I check something else.
Old Nov 23, 2009 | 11:05 PM
LynnEdwards's Avatar
Electrical Expert
Make sure you go to a low enough scale on your meter to see the trigger voltage. It should be 0.3 to 0.5 volts AC so you should be on the lowest AC scale.
While you're at it, measure the resistance of this line to ground. It should be around 150 ohms.
Just for grins, what is the resistance of your kill switch connection to ground? Do this with the engine stopped, kill switch off and ignition switch on.
Old Nov 24, 2009 | 11:10 AM
reganl's Avatar
Thanks for the info, I will try it this weekend, then let you know.
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Slagpolaris
Sep 5, 2015 09:41 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
