1999 honda trx300fw timing
Old Nov 23, 2009 | 05:17 PM
florida mike's Avatar
Default 1999 honda trx300fw timing
I'm trying to put my timing chain back on the gear and onto the camshaft but I believe we accidentally moved the bottom gear and now the timing could be off...How can i check to see if the bottom gear is in the right position. Any answers would be helpful...thanks ahead of time.....
Old Nov 23, 2009 | 09:44 PM
Sisco1957's Avatar
on the left side engine cover you will find two round plugs with a slot. The one farther back is for the starter reduction gears. Through this hole you can use an allen wrench to turn the engine counterclock-wise. The plug to the front is over the flywheel(rotor). You will see a "T" and a "F" mark. Align the T mark with the center of the hole making sure the engine is on compression stroke(vallves closed). This gets piston at TDC. Align marks on cam with surface of head and it should be in time. Hope this makes a little sense. I can do it better than I can explain it.
Old Nov 23, 2009 | 11:17 PM
Thanks a lot that did help a lot but one more question how do i make sure it is in the compression stroke if I don't have the head cover on yet with the rockers to open or close valves...thanks again
Old Nov 24, 2009 | 09:05 PM
Sisco1957's Avatar
Look at the lobes on the cam where the rockers will touch. The high spots(pointed side) on the cam will cause the valves to open and the lower spots(rounded side) lets the valve close.
Old Dec 20, 2009 | 11:28 PM
Wendell Earl's Avatar
I'm trying to find out the timing marks on a cam and the crank for a honda rancher 350 2002, Does anybody know?
Sjrpp
May 2, 2023 03:59 PM
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
