Stearing Stem Squeaking
Old Nov 25, 2009 | 08:56 PM
polaris man with issues's Avatar
Default Stearing Stem Squeaking
Hello i have a 05 polaris sportsman 500 ho and i have a squeaking noise in the stearing stem bushings. I tried to put a grease fitting in the hole already drilled and when i put the clutch breather on, it hits the grease fitting. Any Ideas
Old Nov 26, 2009 | 10:35 AM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Wd 40
Old Nov 26, 2009 | 11:09 AM
4getful2's Avatar
lube the bushings with the fitting on and then take it out. you could try a fitting with a 90 degree elbow in it. there are different manufactures of fittings and if you look close they do make them with shorter snouts. you may end up just having to take it apart once a year and lubing this. you could try some marine grade grease,it thicker and doesn't wash out as most others do.
Ahtatu
Sep 28, 2015 12:14 PM
Canamaniac!
Sep 4, 2015 06:44 PM
Sportsman850
Jul 31, 2015 04:25 PM
1966F100
Jul 12, 2015 03:01 AM
mx400
Jul 13, 2000 01:03 PM
