01 scrambler 400 need some help!
Old Nov 26, 2009 | 02:44 PM
hellbilly13's Avatar
Default 01 scrambler 400 need some help!
I just took a 01 scrambler 400 on a trade and it has been rebuilt and runs real strong but i seen the posts about the counter balancer oil and i have no clue where the dip stick is on my bike! the only one i see is the yellow trans dip stick. where is the cb dip stick and the drain pulg!?!?!
Old Nov 26, 2009 | 03:28 PM
ok so i think i found it (under the carb on the case?) but.....it was dry with small spots of rust on the stick, i also pulled the drain plug and a few small drops of rusty water came out! i filled it back up but have yet to start it. what do you guys think?
Old Nov 26, 2009 | 04:40 PM
ftwflh's Avatar
sounds like the seal may be bad on the counter balance.Run it a bit and check again
Old Nov 26, 2009 | 04:57 PM
well i ran it for about a min. and took the plug out, the oil was a light....ish brown. I put more oil in it went to start it with the pull rope(have a new batt. but no charge) and the rope broke!!!! this quad is bum'n me out!!!!!!
Old Nov 27, 2009 | 04:30 PM
Ok I got the rope back on(2 hour job lol) got it all together and fired it up for awhile and shut it down to check the cb oil. It looks better everytime I check so I hope I'm good there. A new problom is my starter won't work when I try I just get a click from under the seat?!
Old Nov 27, 2009 | 06:16 PM
4getful2's Avatar
if the starter hasn't been used in awhile it may just need taken off and take apart and a good cleaning. if it's rusted together beyond repair search for a new one,there is all kinds of different prices out there. try even e-bay. i got mine from pats small engine parts,cheapest i could find at the time.get a new starter drive too.
the starter is underneath ,it was easier for me to take the gas and battery out and lay the bike on it's side,take the skid plate off ,you'll need to take the rope recoil off again ,2 bolts in there(get them started-not tight just start first on reassembly
Old Nov 27, 2009 | 08:20 PM
Yea I'm gonna try get a few rides in before I tear it down for the winter check out the starter, check the seals and the piston. I was told it had a rebuild awhile back .25 over but they used polaris parts I know the stock piston sucks but how are the over bore pistons from polaris?
Old Nov 27, 2009 | 09:03 PM
ftwflh's Avatar
any cast piston will blow on these.Make sure it at least has a forged one in it
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
