Winch failure
Old Nov 28, 2009 | 09:55 PM
Big600twin's Avatar
Default Winch failure
I am starting to have intermittant problems with my winch. It will always feed out when using the power switch but sometimes it will not come back in. I can keepo switching the switch from out/in back and forth and all of a sudden it will work fine. I took the cover off the mini-rocker switch but it seemed like the inside of the switch was completely sealed. Has anyone else had this issue?? I am checking all the connections to look for a bad wire or corrosion but wondering if I should just buy a new mini-rocker switch??
Old Nov 29, 2009 | 07:43 AM
Speeddrive1's Avatar
Most likely the contactor has got moisture in it and corroded.
Old Nov 29, 2009 | 03:26 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
agreed thatthe contact is most likely the culprit going bad. check the connections and if there good then the contacter it self is going bad. replace it and all will be fine. what brand is the winch?
Old Nov 30, 2009 | 10:52 AM
Big600twin's Avatar
The winch is a WARN 2500 and it has a relatively new contactor that was replaced with the recall a few years back. I am going to disconnect and clean all of the wires and then see what happens......With it being an intermittant problem and wasn't sure how to try and diagnose..
Old Nov 30, 2009 | 11:26 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
a good way to check it would be to hook the cables up back wards on the winch it self and if it works when it didn't it is the contacter going bad.
Old Nov 30, 2009 | 01:09 PM
Big600twin's Avatar
AHHHH..... The in then becomes the out(which has been working) on the switch... Brilliant. I'll try that as well after I clean all the contacts. Your help is always appreciated Mr. STENDORI!! I was stuck in the mud last year and I had to free spool the entire line and then wind it the opposite way. Definately a pain in the ()&*.
Old Dec 22, 2009 | 11:19 PM
JSRIII's Avatar
I had the same problem last winter while plowing. I had to flip the winch switch back and forth to get it to work. Sometimes the cable wouldn't go out and sometimes it wouldn't come in. This year during the recent blizzard, it decided to stop working completly. A buddy of mine, who is a motor head, and I played with the switch and the winch connections and finally the contactor.
Start by removing the contactor from the battery and winch cables. Connect either the blue or the yellow lead to the negative (black lead) and then use a jumper wire to connect the positive (red lead) to the remaining winch wire. You can also swap the wires as one way the winch should wind in and the other way it should wind out. If the winch works in both directions, then the contactor is bad. Contact your dealer and ask if they have a replacement in stock. In my case, my Polaris winch used replacement contactor with part number 2876657. It was $99.99 plus tax. Installed it today and the winch is working just fine. Probably won't snow now for the rest of the winter.
Old Dec 23, 2009 | 05:18 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
hhhmmmm that sounds like what i said
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
cboler9
Sep 24, 2015 08:35 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
