Chinese ATV Carb. choke problem
Old Nov 29, 2009 | 09:10 AM
maxpac4's Avatar
Default Chinese ATV Carb. choke problem
Hi,
I purchased a "fixer" redcat 150 mpx. The elect choke doesnt seem to work. I can get it running after priming with gas. Bought and installed
a new carb. yesterday. It has the same problem, runs fine after priming,
but won't start. I'm not sure if the vacuum lines are hooked up correctly.
There are 2 connections one on either side of intake pipe. New carb only
seems to need one? Help!
thanks, Phil
Old Nov 30, 2009 | 07:39 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum maxpac4!
Are you sure its the choke not working? Valves out of adjustment will cause hard starting.. Any way to look inside the carb while your trying to start it? You should be able to see if the choke valve is open or closed...
Old Nov 30, 2009 | 11:58 AM
maxpac4's Avatar
Smile Choke problem
Hi,
Thanks for the reply. There is no seperate choke valve. Just the throttle valve and main slide valve with needle which is vacuum
controlled. I dont think it is valves since I can also get it to fire
if I hook the left side vacuum line to the intake pipe fitting. It will
start then but immediately dies. I determined this temporairly raises
the slide to allow fuel to flow. The engine will not continue to run with
this tube connected. Also it starts and runs fine after engine is warm
no priming required. This is the first carb I have ever worked on with an
elect. choke. The carb is a Ke-Hin (spelling) japanese carb. I'm
pretty sure I need to connect the vacuum lines differently?
thanks again,
Phil
Old Nov 30, 2009 | 04:50 PM
KTM Patrol
Former Chinese POW!
Is it really a Japanese Keihin? That would be a good thing....not too sure what side the line go to, but if you had 2 lines and now only have 1.. You need to plug 1 of the lines/fittings on the manifold.
Old Dec 2, 2009 | 01:17 AM
LynnEdwards's Avatar
Electrical Expert
On my 150cc quad I don't have a Keihin carb but I do have an electric choke (bystarter valve) that enrichens the gas mixture when cold, compared to starving it of air as with a standard choke. Does this sound like your carb?
If so, I think these normally fail in the cold position - i.e. the quad starts fine then runs terrible when warm. If you unbolt the bystarter valve it runs rich, and you can switch to the lean mode by plugging the vacuum hole with your finger. If you take it apart don't lose that little gasket between the bystarter valve and the carb.
I also have only one vauum line from the intake manifold.
Old Dec 2, 2009 | 06:37 AM
maxpac4's Avatar
Default Elect Choke
Thanks Lynn,
Yes this sounds like my carb. I can never get it to run rich is the problem. I am using a brand new carb now, same prob. Hey, I grew
up in Patterson, not far from you.
Old Dec 2, 2009 | 07:23 AM
KTM Patrol
Former Chinese POW!
Originally Posted by maxpac4
Hey, I grew
Where you living now? Still in Ca?
Old Dec 2, 2009 | 01:19 PM
maxpac4's Avatar
No, semi retired now, followed our kids to Lex. KY.
Old Dec 3, 2009 | 07:55 PM
NewportHillClimber's Avatar
elec chokes on chinese atvs always fail. you can get one that has a manual choke to replace it with. usually for under 50 on ebay brand new
Old Dec 3, 2009 | 11:48 PM
xcitmt's Avatar
Have the same prob with a mine... Found out if I fold the choke lever down for the first minute and not let it move it run well.. Just my 2 cents... Kazuma 110..
skinnyr6
Aug 25, 2023 02:18 AM
Frisky2050
Apr 9, 2020 11:19 AM
honda71
Jul 12, 2015 05:56 AM
cornermike
Jul 8, 2015 11:44 PM
honda71
Jul 8, 2015 02:13 AM
