SP 600 Quits after Warming Up
Old Nov 29, 2009 | 03:10 PM
Hoytbow's Avatar
Default SP 600 Quits after Warming Up
What would cause my SP 600 to quit once it gets warm, I can let it idle for 15 min. and it quits or I can ride it for about 5 min. and it quits. It backfires and sputters when I try to restart it. After it sets for awhile, it will restart just fine.Any help would be greatly appreciated. Thanks.
Old Nov 30, 2009 | 01:08 PM
tv4fish's Avatar
"Generally" speaking --- heat related failures like yours are ignition related -- as in bad/weak coil or ECU. It's probably NOT fuel since it will run 15 minutes before dying.
Old Nov 30, 2009 | 07:06 PM
The X's Avatar
Does it only seem to do it when the weather cools off,fall & winter.
Old Nov 30, 2009 | 07:34 PM
Wenty's Avatar
Test to see if your tank vent is plugged. Just open the gas cap a few turns and let it idle. May not be your problem but would cause it to die like that and easy to check.
Old Dec 1, 2009 | 08:41 AM
EPIChad's Avatar
My buddy had a 600 that did the same thing after about 20 minutes of riding. Once it happen it would keep happening until the machine completely cooled off. After a lot of searching he found that the wires were bad right at the stator. He was able to soder them and problem was fixed.
Old Dec 1, 2009 | 06:22 PM
Hoytbow's Avatar
I will check all of these things, thanks for the input. Someone told me that my coil may breaking down after it gets hot.
Old Dec 2, 2009 | 11:08 AM
Kerbbirds's Avatar
Seen stators cause this,.
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
IMLN
Sep 28, 2015 03:32 PM
