Sportsman 800 lift
Old Nov 30, 2009 | 12:34 PM
poho800's Avatar
Question Sportsman 800 lift
I installed a superatv 2in lift on my sportsman 800, however i didnt grind the strut housing down b/c the directions didnt say to do so? is any one else running this lift and if so has there been any issues?
Old Nov 30, 2009 | 02:53 PM
700 sportsman's Avatar
what issues are you having?
I don't personally have that lift, but I do think I remember hearing something about grinding down the strut housing, also you may have better luck getting a definitive answer about this over on the highlifter forums, as they are much more into lifts and stuff
Old Nov 30, 2009 | 06:23 PM
poho800's Avatar
I have heard that with a lift the cv boot may rub the strut housing and tear it. I just installed it today and it didnt seem to be rubbing.
Old Nov 30, 2009 | 07:58 PM
helmethair78's Avatar
I think they rub with the 3" not 2". I guess you can grind them later if they rub.....
Old Dec 1, 2009 | 08:37 AM
EPIChad's Avatar
Im not sure on that particular brand lift but on others you have to lightly gring on the aluminum for more clearance to keep the cv boot from rubbing. Check the full travel of your suspension to see if it will hit. Jack up machine and let the suspension sag down, i think thats when they will rub. Also compress the suspension and double check. If it doesnt rub at either spot you should be good.
Jmuddin284
Jan 19, 2026 07:16 AM
Cantbuytime
Aug 17, 2015 06:33 PM
Cantbuytime
Aug 16, 2015 09:13 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
