Need a small ATV for yard work
Old Dec 1, 2009 | 02:07 PM
budedm's Avatar
Default Need a small ATV for yard work
I'm looking for a small ATV for yard work. My wife will use it mostly. Something that won't tear up the lawn, auto trans or at least an auto clutch, reverse. Would the Bayou 220 be good?
Old Dec 1, 2009 | 03:28 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
If you want something that wont tear up the lawn. You will need a ATV that has a differential not a straight axle..
Old Dec 2, 2009 | 06:39 AM
budedm's Avatar
Can you name a few that have a differential?
Old Dec 2, 2009 | 08:03 AM
TLC's Avatar
TLC
The only ones I know are some Polaris models with "turf mode" but there in the 500-800 cc range. I think they made a 330cc with it also. Here is a you tube on how they work.YouTube - Polaris Turf mode diferencial
Old Dec 2, 2009 | 08:31 AM
KTM Patrol
Former Chinese POW!
The only 1 I know of (besides the Polaris) is the 2006 and earlier Jetmoto Hunter 250. Its ok for real light use but has a weak rear end...any moderate use and it will break..And since its only available used, there is no way I would recommend you buy 1.
Id look for a Polaris..
Old Dec 2, 2009 | 09:34 AM
KTM Patrol
Former Chinese POW!
If you used a tire like this on the Bayou, you would be ok.
Golf Cart Tire — 18 x 850 x 8 Sawtooth | Turf Wheels | Northern Tool + Equipment
Old Dec 3, 2009 | 09:16 AM
Hayashi's Avatar
I've been using a non-diff rear axle small tractor on my lawn for years and it doesn't tear up the lawn at all even when I make super tight turns around trees. It has turf tires though.
Since the OP posted here at Kawi forum, I would suggest a P360 over a Bayou 220 which is now called 250. P360 costs more but it has way more features than 220/250 which is basically a bored-out 185 first introduced in 1985, very old design. If you would be pulling anything heavy, upgrade to 650 level. Important thing is to use lawn friendly tires.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
Sjrpp
Jun 2, 2019 07:25 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
