CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
2004 330HO Battery so hot it was steaming
Old Dec 2, 2009 | 12:00 PM
Bullet69's Avatar
Default 2004 330HO Battery so hot it was steaming
I'm hopeing someone can help. My guage pod will sometimes read fail and my low beam headlights won't work, then my battery started to get so hot that you could hear the steam whistling out from it. I asked a dealer about it and he thought that it might be the voltage regulator?? I brought the battery in and had it tested and it was fine. Just wondering if it might be something else I can check before I bring it to the dealer. Thanks.
Old Dec 2, 2009 | 01:56 PM
justme23005's Avatar
Check the battery voltage, with it running.... Hook up the volt meter, rev the engine & note the highest voltage... if its much over 14.7 its overcharging..... replace the regulator..
also, check to make sure the battery terminals are clean... & make sure the vent hose off the battery isn't plugged.
Old Dec 2, 2009 | 08:53 PM
Bullet69's Avatar
Thanks. I'll try that.
Old Dec 3, 2009 | 07:17 AM
Bullet69's Avatar
Would overcharging by its self cause the low beams not to work and the guage pod to read fail?, Or does the overcharging mess up the voltage regulator which in turn causes these problems?
Old Jun 8, 2010 | 01:02 PM
Bullet69's Avatar
Brought it to the dealer. It was the Voltage Regulator.
COFatboy
May 2, 2020 12:06 AM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
bradco
Aug 21, 2015 08:11 PM
400H0
10
Aug 20, 2015 07:34 PM
