Awd
Old Dec 5, 2009 | 05:57 PM
bhunter15's Avatar
Default Awd
doees anyone know if u have a sp500 awd if u can somehow disconnect the awd and use the switch for the 4wd only so then u can run it 2wd only and use the switch to turn on 4wd
Old Dec 5, 2009 | 06:14 PM
Why would you want to change it? If the switch is in 2wd you are in 2wd. If the switch is in AWD you have it in less than 1/5th of a turn difference between front and back tires. It's seamless. If yours isn't doing this, than there is something wrong.
Old Dec 5, 2009 | 10:14 PM
user493's Avatar
Moto Psycho
Do you want the 4WD to automatically come on whenever you turn the switch on?
Old Dec 6, 2009 | 12:25 AM
bhunter15's Avatar
ya i want it to be option to have 4wd or 2wd instead of the awd kicking in whenever it senes the back tires are slipping..i think it makes funner, but if its not possible to switch it somehow then o well i was just wondering?
Old Dec 6, 2009 | 06:39 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
what year is your sp 500? the newer models you can leave in awd all the time and it only kicks in when it senses wheel spin as mentioned. other wise if the switch is in 2 wheel drive the awd should NOT be kicking in at all. so as long as you don't have the switch engaged for awd, it should be in 2x4 and not awd mode unless there is something wrong. imo
Old Dec 6, 2009 | 07:13 AM
Spdecat's Avatar
If you leave your switch in 2wd you will always have 2wd never would you have 4 . Only when you move your switch to the 4wd position will you have 4wd and then only when your rears slip 1/5 .
Old Dec 6, 2009 | 08:02 AM
08 rap's Avatar
not to add any cofusion here but i just replaced a seal on my left front and the roller clutch looked good put new bearings in and the hub wont engage. only got 3 wheel drive is there a way to track down or trouble shoot the magnatizing in the strut for thr roller clutch? anyways its a 99 sportsman 500 thanks any help would be apprecitated
Old Dec 6, 2009 | 09:06 AM
RickCJ7's Avatar
Thats how it works awd is 4wd and 2wd is 2wd.
Old Dec 6, 2009 | 10:47 AM
bhunter15's Avatar
ya but it i was watching it and with the switch off and in 2wd and it feels the back tires slip the awd automatically kicks in wether i moved the switch or not. i was just wondering if it were normal or something is just wrong with my engagements
Old Dec 6, 2009 | 11:12 AM
Raven95150's Avatar
Sounds like something is wrong. If the switch is in 2wd, you should have only 2wd. The 4wd should not be kicking in at all.
