Awd
Old Dec 6, 2009 | 11:28 AM
Roofer's Avatar
Doesn't care what people ride as long as they can keep up!
Originally Posted by 08 rap
not to add any cofusion here but i just replaced a seal on my left front and the roller clutch looked good put new bearings in and the hub wont engage. only got 3 wheel drive is there a way to track down or trouble shoot the magnatizing in the strut for thr roller clutch? anyways its a 99 sportsman 500 thanks any help would be apprecitated
Make sure the shear key is still in tact.
Also, I just read something about torquing the nut on the bearings. It has to be correct. If it's too loose or too tight, it will not perform correctly.
Old Dec 16, 2009 | 01:44 PM
Firecaptain9's Avatar
sounds like its stuck in AWD. most likely an electrical connection needs cleaning or tightening, or the switch is bad.
Bob
