Idles fine, press gas and it kills the motor.
Old Dec 9, 2009 | 01:28 PM
dal72's Avatar
Default Idles fine, press gas and it kills the motor.
I have a 2005 artic 50 and when I press the gas the motor dogs and wants to die. Any idea what is wrong?
Old Dec 9, 2009 | 02:30 PM
DODGE57HEMI's Avatar
Mopar Man!
The float in the carb need adjusting as it is causing it to flood!
Old Dec 9, 2009 | 03:02 PM
swampyjunior's Avatar
I would suggest cleaning the carb first before you begin adjusting things. Especially if it was running fine.
If you pulled the plug and checked its color it will tell you what is happening. Black indicates you are running rich (too much fuel) white-ish colr too lean (not enough fuel). In both cases you usually find it is casued by a plugged jet inthe carb or a very dirty air filter.
So start by cleaning the filter and the carb. Then if you are very positive it is clean start adjusting things.
Swampy
Old Dec 9, 2009 | 06:40 PM
dal72's Avatar
Default Thank you
Thank you I will try cleaning the carb
Old Dec 9, 2009 | 07:18 PM
Mopar Man!
Cleaning will be a good start tho I bet the float will still need adjusting. Try using some sea foam for starters and see if that helps any!
Old Dec 18, 2009 | 11:53 AM
Chevellerocks09's Avatar
Default Clean the carb
sounds like your main jet is clogged.
Old Jan 5, 2010 | 09:43 AM
99farmboy's Avatar
You might have a touch of bad gas also. I had this happen to a Honda Recon and I could get it to start and as soon as I give it some gas it died. Raplaced the fuel and added Seafoam and now runs normal again.
KimSJoh
14
Jul 18, 2015 07:20 PM
clsharky
Jul 13, 2015 02:07 PM
ranvette
Jul 12, 2015 06:34 AM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
MNatv89
Jul 7, 2015 11:36 AM
