Can't hit the rear driveshaft U-joint grease fitting
Old Dec 10, 2009 | 04:36 PM
Snookie's Avatar
Default Can't hit the rear driveshaft U-joint grease fitting
I recently changed my oil and lubed whatever grease fittings on my Outlander 400 I could find. I could not get my grease gun into the universal joint at the rear of the rear drive shaft. I was able to get onto the front universal joint on the rear drive shaft, however. I'd like to get some grease in that thing. Do I need a special tool/grease gun fitting or do I have to disassemble the driveshaft? I'm using one of those "mini" grease guns. I don't think I'd even stand a chance with a full-size.
Old Dec 10, 2009 | 08:46 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
You just need to rotate the U-joint so that the side with the zerk fitting opens up more. Really easy to do if you have a lift.
Old Dec 11, 2009 | 05:27 AM
Snookie's Avatar
Hmmm... I moved it forward and back with no luck. I have a pulley system for butchering deer in my garage and a small floor jack. I see what you are saying though. I'll give it another go once it warms up again (10 degrees here this morning and 20mph winds!).
Bratman2
Aug 6, 2022 01:42 AM
greg74
Sep 10, 2019 03:03 PM
DeFox500
Aug 14, 2015 05:59 PM
toonces
Jul 28, 2015 01:58 PM
Rider252
Jul 6, 2015 03:37 PM
