01 ds650 quit running out of nowhere
a couple days ago i was out at a gravel pit not rippin but just puttin in and i went up the hill didnt romp on it or anything and as soon as i got to the top and started to go back down again it shut off.
i checked the gas and on off switch.. it has spark and fuel i did a compression test and it read zero..
cam chain snap?
it turns over fine. i dont hear clunking.
oh and it will backfire every once in awhile
but it was odd it went right up the hill no problem and then died
cam chain snap?
okay battery is good i did a load test.
i will add this.. when i ride doubles (i know ur not supposed to) but when the rear shock would compress it would sound like my valves were stressing or my chain was 'whipping' like bouncing but from the header area. i thought it was a loose header spring.
i wanted to ask and make sure/ try to pin point the problem area before ripping it apart
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
